How can I solve the Selection Problem in (Editor mode)? Pls Help
Hi MR, MRS!
I’m so excited and feel so nice to talk to you. I would like to know the solution to the fixed Selection problem in (Editor mode) which means that when I want to drag and select some element icons’ texts’ buttons … etc that I want in order to edit such as make a change for its position’ it seems like it doesn’t support. It always keeps selecting all the element on the page such as all the images’ icons’ texts’ buttons …etc that I don’t want or need. So can anybody here tell me the solution to fix this problem?
Here the Image related to the problem:
For example: I just drag and select only for element Text (Oops! 404) and element Text (It happens sometimes) in order to make an element in to group but it automatically select all the element on the page for me. So can anybody here please tell me how to solve this problem?
Thank you.
May I know does anybody here have the same problem as mine?
I’m not quite sure how that would happen but it could be due to the ordering of different elements on the page :man_shrugging:
But if it’s a problem why don’t you just select the element you want to select from the elements tree?
Screen Shot 2022-05-02 at 10.25.11 am
Josh @ Support Dept
Helping no-code founders get unstuck fast :rocket:save hours, & ship faster with an expert :man_technologist: on-demand
Thanks for replying to my message!
Yes I tried but it seem like it doesn’t work because once I click on the Elements tree and select for an element I could only select individual element at the time, I also tried to click on Ctrl key and select on the element that I want to select it worked but it take along time for me to click on Ctrl and select one by one instead of drag and select which could make it easy for me before but sadly it doesn’t work for me currently, once I drag my mouse it automatically select all the element.
