Hi, Bubblers!
I hope you are all having a great day!
I was wondering what the best way to check why my application is maxing out on capacity. This has been an ongoing issue that @draked123 and I have been dealing with and a solution would be great!
That’s such a hard question to answer. It could be one person doing one very complex or poorly built action. It could be a ton of users performing very simple actions all at the same time. Maybe there are a bunch of API workflows running? It’s almost impossible to tell, and will vary from app to app and builder to builder.
New issue I’m having @andrewgassen, not sure if you have a solution for this, but we are transferring data to different data types and we are getting “Operation Timed Out” any fixes for this?
Could you explain to me how your capacity is actually calculated? I want to build a social network with .bubble for a large userbase. I’m just researching now if .bubble will be cost effective for project or to build elsewhere.
I resolved many of my issues by not using :filtered, but instead using the constraints in the Do a search… function. I’m not 100% sure on how capacity itself is calculated, but maybe @andrewgassen@eve@josh or @emmanuel could help you out on that.
