Hello everybody.
I would like to be able to creat an input for address which allow the user to find easily the address he is looking for.
(with an auto-complete fonctionnality)
Here is an exemple of what i am looking for.
https://developers.google.com/maps/documentation/javascript/examples/places-autocomplete?hl=en
Thanks for the help.
Regards.
Vincent.
The Bubble map does that.
It’s a 2-step process. First, create a search box. Then configure the search box to look for geographic places. When the user starts to type the address, he/she will see the results.
If you want to show the search result on the map, set the marker to be the map’s value.
Hello
Thanks for the rapid response.
I will look at it as soon as possible.
Vincent
