You sent me this:
I was curious as to where you found it, it might be a resource I haven’t yet found.
Thanks for your help (and patience) you’ve been super helpful!
You sent me this:
This is my app where I created the example specially for you, for your case. I didn’t find it.
There are many open apps where some users where kind enough to create a lot of examples:
hope it helps, good luck
Perfect, thank you.
