Hello, I hope you are all well. I have seen testimonial slider on other sites, the example below shows the picture. I am wandering how to apply this on my bubble app
Thank you
Thank you
I would add a repeating group (fixed to display 1 cell) inside a group (of type “align to parent”) and on top of it the left/right icons and the 123 buttons, for the left/right use the “show next” and “show previous” actions or I would use custom states to track the images. Instead, I would just use a plugin for this.
thank you very much for respond i will definitly try that
Also, it can be achieved by using an image inside a group of type “align to parent” with the icons and buttons, and relying on the custom states to track the images, this can help to add sliding left/right transition.
