How to fix - Bubble input fields don't use appropriate HTML element names
I have a simple landing page with email capture. To do the email capture, I’m using:
  • Input forms > Input element (where the user types their email)
  • Button (where the user submits, this triggers an event to add the email to the DB)
I’d like to start using an email referral software called Sparkloop, but unfortunately Sparkloop’s js snippet cannot detect an email form on the page.
It’s looking for a element with an input field of type=“email” that triggers a form submit event on submit.
The bubble input does not use the element. Any tips on how to fix this easily? Or do I just need to use a custom HTML box?
