how can i index on google
a product page
that shows dynamic data from the database?
for example:
Ecommerce website
100 products on the database
with fields like Name,Price, Pricture etc.
there is Product Page that contains a group
that showing all the product data,
i want every product to have it’s own URL
(i understand that there’s an option for dynamic URL)
and most important:
i need google to index all the products
as different pages/URL’s
hope i’m clear enough
searched but hadn’t found a solution yet…
Create a “catalog” page with all the links on it. Google should then find it and crawl.
So simple?
Happy to hear ,
anyway of doing it automaticlly and not manual one by one?
i had a URL field at the database for each product
Repeating group should do it.
Build the URL as a link in each box.
Nigel you’re awsome
i see your answers all over the forum
thanks man!
really appriciate it.
https://support.google.com/webmasters/answer/4559176?hl=en
Also, use the Google Search Console, “Open as Google” to check and index if needed.
