How to make JSON body parameters Optional?
In POST method call I have lots of parameters:
But Bubble gives me error if I don’t fill them.
I already ticked “Allow Blank” option, but it doesn’t help. I don’t want them private, because I want user to have opportunity to choose to fill them or not. Any ideas?
Hey @nessessarius :wave:
If you put in the dynamic data, it might work even if the dynamic data is empty. Give that a shot maybe. :man_shrugging:
If you click on dynamic data and then don’t actually choose anything, it should also work. It will just say ‘click’ and it should remove the error.
Hope that helps! :blush:
@j805 www.NoCodeMinute.com
Yes, indeed! Thank you, I didn’t consider this variant. :sweat_smile:
