How to remove default alert without using plugin
I have created a registration page using User data thing.
I want to remove default alerts without using any plugin.
Here is my work
Element Events - Bubble Docs
What to do for a specific error alert like I want to show alert when the password input is not matched with the Confirm password input.
That’s what I’ve shown above… just add your own alert or popup (whatever suits your UX) and show the error message.
In my case, create button is the element which is running the workflow. If I am not wrong then if I applied the above steps then it will show the same alert on any error. But I want specific alert on specific error of the workflow.
But, I got it done through 'An input’s value is changed ’ only when [input not valid or …]
You are wrong…
it will show the specific error message for the particular error (i.e. “passwords don’t match”, “invalid email”, “please enter a password”, etc.) which you can define in your app settings…
Oh ok then I am doing something wrong
Evidently…
