Hi Bubblers, first post here after some months working and reading with you.
Several hours trying to solve it, but here it is how to reverse the alignement of group elements. Hope it can help the community!
OBJECTIVE:
In my case I have a row group with two group elements inside, white (off-white) and blue colored groups…
…with the goal of moving the blue group to the left side of the white one (also changing its color, but not the topic we are focused on):
SOLUTION:
- Add to the parent group…
…an ID Attribute name in the lower part of the Appearance menu:
Note that you should have checked this latter option first (Inside Settings > General):
In my case it is conditioned as:
- Look for the HTML header input inside Appearance of your page, and change the flex-direction of your group to row-reverse:
I tried it in so many ways with the following format:
<style>
#changeOrder {
flex-direction: row-reverse;
</style>
and different functions like “direction”, “display”, “position”,… but the secret sauce is not the function you use.
The key is that we want to apply this change of order into a container that Bubble creates (red) between the Parent group (green) and the row elements (white and blue), not the parent itself.
This is why I realised and used
#changeOrder > div.bubble-r-container.flex.row
in order to transfer the style to their “div.bubble-r-container.flex.row” child, as it does not have an id and I only want to change that one.
If you used…
<style>
.div.bubble-r-container.flex.row {
</style>
…you would change all rows in your page, not what you arte maybe looking for.
So the functional solution would be this one:
Maybe some of the experts here have a better method than this one, but I truly all posts related to this one and none of them said anything about this “middle-layer” container.
Hope it helps!
