How to send data from repeateble group index to popup
Hello community
i am doing simple store that would open popup form with pre-loaded data from repeatble group
this is what i have settled
Снимок3
what i have done wrong?
Check your parent setting to be sure that the data source is correctly configured. I think you have a group (this is the parent) that may not be set to the Popup data as source.
you are 100% correct, i don’t know how but i missed that.
thank you
