I can't work out how to create a hover state for my nav
hi, im making a navigation and within that I have focus groups that drop down when my main nav is clicked on. issue is I cant seem to identify how to make the drop down come down when the main nav button is “hovered”
When I click on my main nav button I am putting the focus group to (drop down) and hit “workflow” the automatic workflow route is “when this button is clicked” there’s no way for me to edit it to “when this button is hovered”… This is different from the conditional tab of the button bc you can’t choose “when this button is hovered” then there’s no element to select that means your drop down will appear.
Please help! Also I’m very very green so I may need the answer really spelt out for me. sorry and thanks
From what I understand…
I think you should add this workflow :
  1. Go to workflow tab.
  2. Add a new Event : Do when a condition is true. Only when = When button is hovered.
  3. Action : Toggle an element.
Don’t forget to make the condition run everytime. You will find this option in event settings.
And you will might also need to add another workflow, i.e When button isn’t hovered,
Hide/Toggle groupfocus.
Thanks so much, it felt like this should’ve worked but it didn’t :frowning: not sure what’s going on with it.
If you need help, I can connect over a call. You can DM me anytime. Or find me on LinkedIn. LinkedIn.com/in/sahibsingh111
