I have a problem statement- how can I get a user's currency based on their location?
I’m working on an application that has users from multiple countries. I sell products on the platform, and I want to display product prices in each user’s local currency based on their country. What is the best way to detect the user’s currency and show the correct prices?
Hi @mayankguptamg462 :waving_hand:
I’ve never done anything like this myself, but the most logical approach to me would be to use a plugin or some code to detect the user’s country based on their IP address. Alternatively, you could simply ask users to select their country during signup.
Then you could integrate with a currency conversion API, such as https://currencyapi.com/, so you can display your website prices with a reasonable level of accuracy in the user’s local currency.
You can use the Currency by Location plugin for Bubble. It automatically detects a user’s currency, country, country code, and city in real time based on their browser location.
This makes it easy to display product prices in the user’s local currency without requiring them to select their country manually, making it a great fit for this use case. Once you have the user’s country or currency code, you can use any reliable currency exchange API to convert the product price into their local currency. There are several APIs available that provide real-time exchange rates, making it easy to display accurate localized pricing.
:link: Currency by Location Plugin | Bubble
Wartinlabs
@wartinlabs
@wartinlabs thanks a lot, it worked… Pretty easy to use!!!
