Need help pricing
I am building an app that has to be globally present however in the pricing tab I want users to use their currency for payment. How can I achieve this? My payment provider is razorpay
It depends on if you are displaying it with a razorpay provided page or if you are displaying it directly in your Bubble app. If in your Bubble app, then you can use the format as operator after numbers which give an option for using currency and then choosing currency symbols.
All of this will need to be dynamic so need conditionals.
Love the idea of going big right out of the gate. Tackle the world and nevermind all sage advice out there to start with a small target market and then scale out.
Because of this need, you should create an option set that has all country code values, and then attributes for a text based currency symbol for all countries in the world. Then you need a plugin to capture the users country code from the browser and the conditionals on the text element displaying the price to use the option set values based on the users country.
Then need an api for real time currency conversions so you can display your pricing accurately based on current currency fluctuations against your companies currency, or in the option set have another attribute for all of the prices in the different countries/currencies.
@boston85719, do you know of any option sets available for copy and paste from an existing Bubble editor? I have need of this, but thought I would check on the forum and see if it exists before creating it.
Nevermind… I ended up creating a new data type instead on an option set because it was the only way I could think of the easily import a .csv file. I had ChatGPT create the .csv file in a few seconds. Hopefully it’s right!
The use of data type instead of option set for this will just cause you to consume WUs every time you need the country values, which may be quite often.
There is a free chrome extension that makes possible to import CSV for option sets that I used in past and it does its job.
Good point about data types consuming WUs. I will look for the Chrome extension you mentioned and give it a whirl so that I can use an option set instead of a data type for the currency symbols I need. Thank you for the suggestion!
