I need help with a repeating group
Im curious, is there a way to make a “repeating group” look like this, with each box spaced
Sort of. :+1: You can do something like this by adding a group into your repeating group. Then center it horizontally and vertically with equal spaces on the sides. Also make sure the repeating group separator is turned to none. Does that make sense?
Hope that helps! :blush:
@j805 www.NoCodeMinute.com
  • One-on-One Tutoring
  • eLearning Hub
  • Video Tutorials
  • No-Code Classes
thanks, i will try this out
No problem. :blush:
