Input box is not responsive
hey, iam new to bubble . i have small prblm and I cant fix it. the input box is notresponsive. i attach a screenshot.
Make sure you haven’t set a fixed width or minimum width for the input that is greater than the intended responsive width.
actually, it is doesn’t have fixed width
What about that gradient region in the footer?
Are you sure the email input is in the correct group?
Please fix min width outside of the input group
Apparently your input is grouped with a label, so like @bubbledeveloper1 said, check the minimum width of this group.
