Is it possible to have an input element not shown on the page but it still able to accept input. I have tried “Do not show on page load” but that doesnt appear to work
What kind of input are you trying to accept?
I want to scan a barcode, it all works OK if scanned into an input field, but i want to scan it and it not be displayed
If an element’s not shown on page load then it won’t be usable until it’s shown.
Are you using a plugin for scanning the barcode? Which one?
Hello!
You can set the input as visible inside a popup that you never open. When the page loads the popup will be loaded so it will act like a “hidden popup”.
This way the input will be able to receive values that you send it to it via workflows.
Hope this helps!
