Is it possible to build another no-code tool in Bubble?
I think Bubble is way too advanced to be built “within” Bubble, but what about something simpler like a Notion? Or maybe even GSheets?
I’ve got a few drag and drop website/funnel/email builders ranging from basic to full fledged alternatives to wix/squarespace/clickfunnels with full ecom, payment processing, a/b split testing, etc.
Notion isn’t hard with some plugins like editorJS.
None of it is vanilla bubble and all using custom built plugins though.
I have a few VERY simple page builders/editors that are vanilla bubble though.
I think it would be possible but hard
yes. posible
I’ve built some complex form and design tools in Bubble and, while it’s not a walk in the park, Bubble’s flexibility is pretty solid. It takes a fair bit of playing around and some serious iteration to nail down what you want, but it’s doable.
If you’re just looking to build something for personal use, grabbing an off-the-shelf tool might save you a heap of time. But if you’re up for the challenge, Bubble’s a decent choice to build something tailored.
