Want to see if I can build a code editor that runs code and shows output for Javascript. Is it possible?
Hi @kalbondada
I think you might find you have issues with this. I know using JavaScript inside Bubble does cause some issues and unless its in a plugin you might find this difficult. Then there is no guarantee you wont hit a conflict within Bubble if some one codes something Bubble does not like.
You might want to take a look at some of the other tools like Backendless (they now have a new UI builder) or Wappler which are probably more suited to this use case.
Maybe some of the Bubble JavaScript wizards can pipe in here and provide a perspective.
Yeah, it’s doable, all you have to do is embed a ready made editor that evaluates it, your page would look something like Codepen.
