Is reshaping the group element into things like triangles, for example, possible?
Hello
Is it possible to reshape the group element to be like a triangle or weird shape like that?
I’d like to try and create a bunch of weirdly shaped group elements, that I can still put other things inside of it, and organize them on the page however I want.
If anyone knows a way to do this, all advise is appreciated.
Thank you
Bubble doesn’t support this by itself.
The most you can do is make a circle by increasing the roundness of a group.
BUT
I believe you should be able to do this using custom CSS
Here’s a plugin that allows you to insert custom CSS onto elements in Bubble:
Thank you for replying.
I’ll take a look at this plugin.
