My app’s working functionalities suddenly broke. All the workflows seem the same as yesterday. Are you having issues too, or is this a specific problem on my side?
Are your workflows dependent on any plugin data types or api objects?
I also have some issues, looks like wome workflows freeze, don’t know exactly. seems to be on workflow with custom event havintg return data
EDIT
in fact it appears that backend works ok, but data realtime refresh on front has problems. after refresh the tab , i have the good display. ..
As I reviewed, real time API refresh not working correctly and also “Trigger a custom event when data changes” actions completely broken. We contacted with support and monitoring the process.
“Trigger a custom event when data changes” also broken @fede.bubble
I can confirm that there are issues with real time updates even if the status page says it’s been resolved
Same.. also action still broken and it makes a big trouble
same , looks ok at a moment, but now , again many issues with RT upadate
I’m still having trouble with real-time data; the database updates, but I don’t see any response on the screen. The status on the Bubble page is outdated.
I’m still seeing some real issues with real-time data.
I’m noticing that quite a bit of information—even simple counts—isn’t updating despite changes.
Refreshing the page displays the correct data; even a group refresh works.
In my opinion, we haven’t returned to the original functionality since the issue with the latest update. Are other people experiencing the same problem?
EDIT : just seen an new post has been today about that…
