Hello everyone. I am trying to setup a monthly recurring payment for my users. As of right now, what I have is- the user subscribes to a monthly plan → the updates takes place in the user account and an api workflow is scheduled. This workflow is triggered after 5, and it replenishes the credits available for the user. I have noticed this workflow works only once, and after making the change after 5 days, its gone. I was wondering if there is a way to reschedule the same api workflow after making the change.
I am using stripe for the payments. I was also wondering if there is a way to get a notification or something similar from stripe, which will tell me, if the user has been charged after 5 days, and i can update the user account based on that. Which will ultimately allow me to get rid of the above approach, and i can implement the same with database triggers.
Any suggestions, is super welcomed! Thanks in advance.
You can set up a recurring workflows in Bubble. After your workflow runs, you can schedule it again for the next month. Just use the “Schedule API Workflow on a date” action again at the end of your workflow, setting the date to “Current date/time + 30 days”.
As for Stripe, you can use their webhooks to get notified about successful payments. You’d set up an API endpoint in Bubble to receive the webhook, then trigger a workflow when a payment succeeds. This way, you’re directly linking the credit replenishment to the payment event.
Hope this helps! Let me know if you have any questions.
