Issue happens only without debug mode
Having an odd issue where data doesn’t load in the feed I’ve built (most times but not always) but if I add ?debug_mode=true it works fine every time, making it hard to diagnose.
No errors in the JS console.
Any suggestions?
Can it be a timing issue? Maybe with debug=true the workflow runs slower. F.i., steps in the workflow might be executed simultaneously. You can prevent this by including the result from previous steps in steps after that or using a wait step (although this is not considered a good practice).
Example:
