Hello All,
I am facing a peculiar situation with a particular page in my app, which was working fine until recently.
The situation is:
when I run a workflow, with the debugger-Normal, the results are not as expected (pop up with empty values, link opening a blank window etc)
however when I run it under slow or step-by-step without changing anything, the results are fine as expected!
I thought it could be a timing issue because of a couple of API’s, so I introduced so many “pauses”, it still didn’t help. However I can see that the data processing was correct, its the display of the output that’s causing issues.
When I ran in slow, (without any pause in between steps) I could see all the workflow was lightning fast and the end result including display is fine. so theres is really no neccessity to introduce any stops.
It just the debugger normal mode and the run mode without debugger are throwing the errors.
Once in a while I see- ‘We’ve hit a temporary bug’
I have recently moved to my own domain.
This is driving me crazy.
Any help will be appreciated. Thanks
Sorry you’re experiencing an unexpected behavior. The general rule with the Bug category is as follow:
- If you’re not sure it’s a bug, and want confirmation from the community, please go ahead and post here
- If you’re 100% sure this is a bug, because you see a message ‘We’ve hit a temporary bug’ or if an action never ends, go straight to our Bug Report Form, it’s a better way to tell us about the issue so that w can fix it.
Sorry about the bug!
