Issue with Zapier Trigger in Workflow (wrong data type found in records)
Hello Bubble Community,
I hope this message finds you well. I’m currently experiencing an issue with a Bubble.io workflow that I’m hoping someone might be able to assist me with.
I have a workflow set up to trigger a Zapier zap (Zap ID = “create ACP”), which is designed to generate a Google Document for a specific ISO 27001 policy. While I have two other similar zaps working fine, I’m running into trouble with a third one.
Here’s the situation: I duplicated a working zap (acceptable use policy), and then modified the new zap to handle a different policy. The trigger in Bubble.io was changed to “create acp” and is associated with my Access Control Policy data type. However, during testing, the zap seems to be pulling data from the original record (Acceptable Use Policy) instead of the new one (Access Control Policy).
Here are the troubleshooting steps I’ve taken:
  1. Double-checked the Bubble.io trigger (“create acp”), and confirmed it’s working correctly and associated with the correct data type.
  2. Refreshed the trigger data in Zapier.
  3. Set up the Bubble.io trigger again in Zapier.
Despite these steps, the issue persists (update : I managed to setup 5 zaps correctly, but the issue goes on for 4 other ones, and I litteraly follow the exact same procedure to deploy this workflow). I’m at a loss as to what might be causing this, so any advice or suggestions from the community would be greatly appreciated.
I suspect that the error comes from bubble side, despite triggers setup correctly.
Looking forward to hearing from you.
Thanks,
Tris
Ok, actually, there is a “gap of 1”, meaning that the data for trigger N is associated with trigger N+1. But not systematically because 5 zaps are active, since the correct data was being pulled out. Any idea?
Note that I did all obvious checks such as making sure that in Bubble Zapier plugin, triggers have unique name, associated with the right data type, etc. Same within bubble workflow, for each new page created, the WF has the data type correctly put and associated with its right Zap trigger.
i’m also facing the problem, if you have the solution please let me know
Ok, the solution is simple:
Ignore the wrong data during this test and implement your workflow anyway.
It actually works in production.
Let me know if this solution worked for you.
I’ve the same problem again, but this time I can’t make my zap work because I need zapier to recognize new data fields created in bubble.
Any idea of how to deal with this wrong data type being found by zapier?
Ok found the solution again.
If zap is associated with data type A, but zapier shows me records from data type B, which prevents me from calling some data fields from data type A later on in the zap workflow, I can create the required fields in the data type B (named exactly after the fields from A), trigger a new record, and zapier will detect the updated record with the fields I want, and then I can put the zap live and it will work.
