i have chatbot platform and i need to load initial chat page in hidden iframe on every page view. Only when user click button and iframe appear, i need to load rest (group with searches, etc…). So i made listener for post message when somebody clicks the button.
Now i need to trigger workflow when message come. So i created very easy plugin to trigger workflow, when i call function “event_trigger”.
Problem is, that this element plugin loads with page (and works) only if i have iframe opened. So, if iframe is loaded in background without visibility, plugin doesnt load and bubble doesnt find plugin function “event_trigger”.
Here is element code:
function(instance, properties, context) {
var fnName = "event_trigger";
window[fnName] = function(value) {
instance.triggerEvent("event");
Is possible to somehow make it works?
Thank you for any responses.
Michal
