Lock focus group? Or create dropdown with floating group?
I’ve been continue to search the forum to a problem I am having with group focus getting shown and maybe somebody in this thread would know the answer to what I thought would have been a simple implementation
If anybody has any ideas it would be much appreciated.
Hello,
How did you manage to make the groups tight to the text in the expense category?
I am facing the same problem with Date/Time Droppers. Has anyone found a solution to this ? The focus group closes when the Date/Time Droppers is clicked.
Hi, I created this solution to block a focus group (i.e. prevent it from closing when clicking on another object or page)
Basically I use the event “Do it every 5 seconds” with the condition in which the user makes visible the object, if it is for a floating dropdown customize (it could be activated through a state) and it is for a shopping cart could be with a scroll position, etc.
Then basically the workflow should be to show this focus group with an interval of 0 seconds, so that it does not disappear, and then when the user does what he has to do, hide it, in case of the dropdown change the state of the state, in case of a cart when he makes the purchase, etc.
I hope it has served
Mate, you have made my day, week and may be a year. I was playing around for a long to come up with a custom dropdown that works! Together with the custom state which i set to Yes/No it works suoper smoothly! Great solution! Thanks a lot!
