Hello Bubble Community,
I need help troubleshooting an existing Bubble application. I have been working on this issue for approximately one month and would really appreciate some guidance.
My application includes:
User login and signup.
Stripe subscriptions (active and trialing).
A maximum of two devices per user.
Browser Device Information - BEP plugin.
A USER_DEVICE data type containing device_id, device_name, user, and is_active.
The problem:
I have experienced login problems and inconsistent device validation. I need existing registered devices to log in normally while blocking a third device.
My login workflow includes:
Log the user in.
Check Stripe subscription status.
Check registered devices.
Register a new device if the user has fewer than two.
Show a device-limit popup and block access when the limit is reached.
What I have already checked:
Device fingerprint values.
USER_DEVICE search constraints.
Workflow conditions.
Issue Checker.
Subscription status conditions.
I suspect that the subscription validation and device-limit workflows may be interfering with each other, but I have not confirmed the cause.
My questions:
What is the correct workflow order for login, Stripe subscription validation, and a two-device limit?
Could a Terminate Workflow action or conditional logout prevent device registration?
What is the safest way to temporarily disable the device limit without affecting login, Stripe, or user data?
I would prefer to fix the existing workflows rather than rebuild the application.
Any specific suggestions would be greatly appreciated. Thank you!
