Heading says it all. why can i no longer make a part of a text bold by using xxxxxxx ? Is it due to the new responsive engine or something.
edit: ironically [b] [ /b] worked in the paragraph above lol.
Hey Jesse,
It seems to work here:
What element are you using?
The element is a button.
Hey Jesse, indeed, does not seem to work. I also tested a page which was not converted yet and there it also did not work btw.
As a workaround, is it an option for you to use a group with a text in it as a button (since clicking a group can also start workflows)?
Hi Jesse, I’ve had such instances in the past. However, a workaround I found was to use the rich text editor to make the text bold.
I don’t rich text editor is on buttons either
