Using both bold and regular formatting within a single text element
Is it possible to apply both bold and regular styling within a single text element in Bubble.io, without having to stack multiple text elements? For example, achieving a format where the text looks like this in one continuous element.
yes, below the input field on the editor panel is a small text that says Rich Text editor, after clicking that you can select whatever you want and make it bold or use diff colors
Thank you!! :slight_smile:
