Hey Bubble team,
I am trying to merge the data fields of an adress (Zip Code, City name and Street name). An individual field does not work because people dont get what they have to put in. I followed the advice inside the forum and it works fine ([SOLVED] Fill adress data type with data from more than one input type?), as long as you stick to English adresses. In the German name for “street” there is the ß. As soon as the symbol is inside a text field the data merging from text fields into an adress field does not work anymore. Is there any easy fix for that or a clever workaround?
Thanks a lot!
Works without “ß”
