Mobile Data Terminal Help
Was wondering how I could make the app automatically issue a warrant for someone after their fine is 5 days old. So like 5 days after the fine was issued it automatically issues a warrant. Thanks
Hey there :wave:
You can schedule a backend API Endpoint and just do a conditional statement to check if it has been taken care of, if not, then it does the action that you set up.
Does that make sense?
@j805 www.NoCodeMinute.com
Hope that helps! :blush:
If you have iPhone you can get the appvalley app which has many unofficials app which will help you in managing your data.
Thanks so much
