Hi all, In one of my RGs I have a numbered sort order workflow triggered by UP & DOWN icons. I just noticed that it was, sometimes, possible for users to click an icon more than once before the workflow starts or finishes. This results in users having multiple items with the same sort order number. Is there a way to limit the number clicks registered by an icon before it initiates or completes the workflow?
This might work:
- setting a yes/no state on the icon to “yes” at the start of the workflow and then setting it to “no” at the end
- then adding a conditional on the icon to not be clickable if this state is “yes”
Thanks @atomicfusion I’ll give that a go.
