Hello all,
Before I get told to read the manual… I did search the documentation, I did search the Forum… couldn’t find it.
To create a Mobile App, is the approach the same as with a WebApp? I doubt, but asking here.
I do not think we can use the lang parameter, correct?
Thanks for helping me learn.
Guy
Hi Guy, just to make sure i understand, you are wondering how to support multiple languages on a native app? If so, it works pretty similarly to web in terms of using the app text feature. The only difference is that you need explicitly specify what your supported languages are in the mobile settings tab. When a user’s primary language on their device matches one of your supported languages, it will use the right app texts. Otherwise, it will default to the primary application language as specified in the languages tab. The user language parameter cannot be used on mobile. App texts (translations) | Bubble Docs
Nick,
Is there a way to change the Current Language in a workflow? As I am explaining, if my device is set to French and I want to allow the user to set my App (prologolf)'s language to English.
Guy
The user would have to change the device language in order to see it in english, if french and english are supported languages
