Hi all!
I have a thing called “02 Analyse pakketen” containing simple information as AnalyseCode and AnalyseNaam (name):
in my app you can select 1 or more “AnalyseNaam”:
I have to send these selected 1 or more “AnalyseNaam” as 1 or more “AnalyseCode”
That’s exactly the problem… I can’t send them as AnalyseCode to the API…
I have tried this, but there is no option to select the “AnalyseCode” it is only the actual “AnalyseNaam” text field:
I also have tried to do a search, and that will find the “AnalyseCode” if there is only selected 1 “AnalyseNaam”. If selected 2, the value is empty…:
Any help is much appreciated!
