Hi there folks,
Was browsing the forum looking for an answer on how to filter results from an API that I’ve enabled with Bubble’s DATA API.
The most important thing would be filtering by date.
Currently the DATA API returns all the fields inside the data object.
Thanks all!
NigelG
4
Filtering from an external app using the Bubble Data API ?
You need to use constraints if so…
Reference | Bubble
Not super intuitive, let me know if you have trouble.
Awesome, I was looking for this but couldn’t find it somehow
