so i have an app text editor that can extend text. But I have to first manually select text/highlight above it( I am using text selection plugin for it to know the value of the selected text)
and then insert at cursor position plugin to insert text where the cursor is.
So what I want to happen is that I dont need to manually select text. Maybe a plugin that will automatically detect cursor position and get the values of above text at maybe around 6000 characters above.
and then the output text on it after the cursor position have some sort of typewriter effect or bg color effect. Right not the generated text just pops out on the editor and its difficult to track
