Hi, I need someone who can tweak the code of this plugin:
I just want to add a typewriter animation on it:
Right now all it does is just insert text without animation
Here is the plugin code below:
//Original from Tim Down
var texttoinsert = properties.insert
function pasteHtmlAtCaret(html) {
var sel, range;
if (window.getSelection) {
// IE9 and non-IE
sel = window.getSelection();
if (sel.getRangeAt && sel.rangeCount) {
range = sel.getRangeAt(0);
range.deleteContents();
// Range.createContextualFragment() would be useful here but is
// non-standard and not supported in all browsers (IE9, for one)
var el = document.createElement("div");
el.innerHTML = html;
var frag = document.createDocumentFragment(), node, lastNode;
while ( (node = el.firstChild) ) {
lastNode = frag.appendChild(node);
range.insertNode(frag);
console.log(frag)
// Preserve the selection
if (lastNode) {
range = range.cloneRange();
range.setStartAfter(lastNode);
range.collapse(true);
sel.removeAllRanges();
sel.addRange(range);
} else if (document.selection && document.selection.type != “Control”) {
// IE < 9
document.selection.createRange().pasteHTML(html);
pasteHtmlAtCaret(texttoinsert)
