Need Help Date Range!
Is there a way I can get a option to select a range and when I select that range of dates it will come up with that date range only?
For example if I did: 01/12/2020 - 09/12/2020 it would come up with that date range.
This is:
Do a Search for Interviews:filtered by [constraint 1: Date greater than or equal to the start of your range / constraint 2: Date less than or equal to the end of your range]
See also: Anything I’ve ever written about dates, but perhaps specifically this, this, and this might be helpful for future.
I am wanting to add a date picker where i can select the date range and a button how would that work. Could you tell me in steps please?
Add two date pickers to the page and in your repeating group you’ll set your search as @keith explained above.
Interview date greater than our equal to Date Picker A
Interview date range less than our equal to Date Picker B
