Need help on relationships between bases
hello everyone, I’m french so excuse me for the translation
i don’t understand the mechanism of relationship between 2 bases with bubble.
i made a very basic example to make myself understood
I created a new database called “cars” with a single entry “name”
and in my user database, I created a relationship with the cars table by creating an entry of type cars
I created a single user, I connected with the help of “run as”
using an input + a button to validate, I created a car called “mercedes”
everything worked well for the creation and we can see the email of my user appearing as creator
my problem is that I can’t display the name of this car in the visual text element
normally it should work but nothing is displayed
this tells me that the field is empty, but it does exist in my database
and I am connected with the only user I created
could you help me understand please
because I think I have understood the relationship between the user table and cars
but it doesn’t work
thanks in advance for your help
Hello, @bubbleweb5151! I did a test here by creating a car table, with two fields, as I will send you some prints. I believe you have reversed it, because the car has a customer, because the customer registration comes before any purchase of a car, right, or of any product, because the product needs to have someone for it to be linked to something or someone. In my opinion of course, I am just a mere beginner too. I will send you the prints. You need to work with nested reapeat groups.
Thank you very much for your answer
U’re almost there, from this image “car” is also empty, I think u’re making the wrong call,
Yes have the relationship set-up well but you have to make it work via a workflow “Make changes to current user”
By so doing u’ll have the the relationship working well…
if you’re not clear with my explanation, I can give you a free 15min call so we can both sort it out
