Need help remembering multiline input text from prior usage
Hi. I’m trying to save multiline text, and leave it in the multiline field for when someone comes back to it after closing/reopening the page.
Essentially, what I’m trying to do is this: someone types in text into a multiline field. They exit the page. When they reload the page later, the same text they left in the multiline field appears as the initial text in that field.
I am also trying to do the same thing with a checkmark box, so that if they check a box and return to the page later, it remains checked.
I’ve tried saving the text as a state and setting it into initial input field but it doesn’t seem to be working. Thanks for your help!
Either save that to your database ( silly, right?) or…
