I’ve got a table that has two rows: first name and last name. How do I use “Do search for” over a text without using repeating group so that I get a list of names in proper order as given?
first name 1 last name 1
first name 2 last name 2
first name 3 last name 3
first name 4 last name 4
I’m using search for DBs: each item’s first name [space] search for DBs: each item’s last name which gives me the following in return.
first name 1 first name 2 first name 3 first name 4
last name 1 last name 2 last name 3 last name 4
Use :Format as text on your search results, then print the first and last names of each item
Gave it a try, still getting the same list as I was getting before.
Is there any other way I can try?
You must have done it wrong.
Maybe share what you did so someone can spot your mistake.
Sure,
So, this is what i did
And this is what I got
Can you tell where did I go wrong?
Thanks
Well that’s totally wrong… (maybe have a look at the Bubble manual first, to get an understanding of how this operator works: Operators and comparisons - Bubble Docs)
The correct way to do this is this:
The delimiter should be a line break (just press the enter key)
Tried the way,
It came pretty close, but there is always First name 1, First name 2
Worked for the last name column though…
Thanks for the help!
Just do it the way I showed (which is the correct way) and it will work.
(what you’re currently doing doesn’t make any sense…)
It worked!
I was again going the “search for” within “format as text” which caused double column. Had to do it with “this column” for both as you told.
Appreciate your help brother!
