Need help with plugin developement
Hi Guys, I’m trying to create a plugin, based on MediaStream but kinda stuck. I have a code which works well inside an html element by itself on the app, but can’t pull the data, even with Javascript to Bubble to save into DB, but I think as a plugin it would work. Would really appreciate someone helping me out, or even co-develop the plugin further. Thank you!
You should connect with Vini and the team at https://www.unlimitedbubbling.dev/
Awesome, thank you I’ll check them out!
