Needing help with mySQL parameters
Hello there everyone, I’m pretty new to the mySQL part of bubble and I was wondering how do I put the parameters in my mySQL query. I’ve been stuck with this for a few weeks now. (See screenshot)
I placed the parameter names in the places I want the parameter text to be.
Hi there, I need help with my bubble -> mySQL parameters. :slight_smile:
Captura de Tela 2020-05-06 às 17.45.32
Thank you, after figuring out a little bit I have found the sulution. Thank you for the response. :slight_smile:
Since you asked the question could you please share your solution you found to the problem?
I’m also trying to resolve a similar problem and wondering if any one has some advice. I have looked through the forum and can’t find a post that solves my problem.
I can successfully connect to my mySQL database and can write a query to insert a new row into the applicable table. The problem I am having is when I try create a parameter and reference that in the query, for some reason bubble.io (or the way I have written the query) doesn’t parse the value through to the db.
As an example, if I hard code the values into the query then I can successfully update the db with the hardcoded values.
But when I create a parameter ($1) with a name title_name (see screenshot below) it does not save the test value to the db.
I have tried the following snytax with no luck:
@title_name
$1
=title_name
@$1
=$1
Any help will be great :slight_smile:
still looking for help?
Hello I’m stuck here I tried with @ ? or simply with the name of the parameter but without success you can share how you did it
The solution is here: SQL Connector SQL Server Parameter Format - #2 by ben13
You need to use the ‘?’ for parameter replacement for MySql.
You guys, my sql worked like this:
from EST_SAIDA_ESTOQUE
where ID_ADMINISTRACAO = ?
limit 20;
ps: I’m using mysql database
