New to bubble and need help finding a template for bubble
Hi. Is there a yelp type template.
I started building the app, but taking alot of hours.
I am on the two week trial period, but would like to jump start the project and put my own tree of items.
Also, once the app is built and ios and android store is done, does anyone have a recommendation to promote it. The project will be primarily college campuses. Thanks in advance
Hey @anon60245838 :wave:
Welcome to the Bubble Community! :tada: :confetti_ball:
Have you looked at any of these templates? Would one of those fit your needs?
As for promoting your app, I suggest finding groups on the college campuses that you can advertise to. Groups that you are already in would be ideal since you already have a rapport with them.
Hope that helps a bit. :blush:
