Hey @zelus_pudding
Any chance to add the typesense JOINs feature to Omnisearch in a near future ?
Hey @zelus_pudding
Hi @zelus_pudding - facing a strange error when trying to sync a table. Here are the screenshots of the error and of the Bubble logs:
Hey Rodrig, my apologies for the delay - just got back from holiday abroad. I imagine you may have resolved this issue or moved on? What I will say given the little context I know is that perhaps your app required a password for runmode. That may have been the issue where disabling that would allow the sync to complete (the plugin needs the app to be publicly available to determine your tableās data structure/option sets).
This is my first entry in the bubble forums, so apologies in advance if Iām breaking any etiquette.
Iāve emailed the creator of this plugin directly, but I thought I would maybe give it a go here too? Maybe someone else has seen this issue and can help?
Iām implementing the Omnisearch plugin with Typesense as the backend, and really pleased with the early results. Iām able to sync my data types and do blazing fast queries using the visual element.
My problem comes though when trying to use the actions for keeping my index in sync, i.e. create / update / delete search record. Iām getting the error shown below. Very very infrequently they seem to work when deleting search records though.
Iāve tried on the app workflows and also in the background workflows, and Iāve tried with several data types, and experimented with all fields sync vs one or just a few fields synced.
Any ideas? Iām using a custom domain (orgoniser.com) and the free tier of Typesense, but I doubt any of that might be the issue. Iāve already purchased the license for Omnisearch, so that should be ruled out too.
The error Iām getting is:
SyntaxError: Unexpected token < in JSON at position 0
at JSON.parse ()
at o.json (eval at build_function (/var/task/util/util_harness.js:37:12), :20:5099)
at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
at async Promise.all (index 0)
at async nl (eval at build_function (/var/task/util/util_harness.js:37:12), :22:6070)
at async eval (eval at build_function (/var/task/util/util_harness.js:37:12), :22:11162)
at async /var/task/plugin_api_v4_alpha.js:198:29
at async harness (/var/task/harness.js:115:15)
at async /var/task/harness.js:152:64
at async withGlobalHandlers (/var/task/harness.js:66:10)
Gonzalo
I am seeing and have confirmed reports that Omnisearch is failing to load search results on page load (we see that our demos are busted as well). Nothing has materially changed with Omnisearch to prompt this failure mode so Bubble must have released an update to how plugins load / work or something very unique is happening. I am looking into releasing a solution as soon as possible.
UPDATE: Omnisearch has been updated to version 2.1.2. This morning, Omnisearch began to fail to load search results for users on page load. The reason for this failure is that Bubble appears to have released a plugin/page update that fixed a long standing issue with Bubble plugin initialization. Historically, on page load, the code that runs in the update section of a plugin can run multiple times on page load. This can adversely affect a pluginās operation if it was designed expecting / needing to only be run once (or zero times) on page load.
In response, Bubble developers have had to implement our own tricks to ensure the update section runs an expected number of times on page load. In Omnisearchās case, we baked in a patch to get the update section to run only once on page load. When Bubble released their update today, our patch made it so the update section didnāt run at all, thus resulting in users seeing empty search results on page load.
Weāre happy to see Bubble make this release (Iām assuming it was a targeted fix for the issue described above) and to be able to release a fix for our plugin quickly. As the issue does affect all Omnisearch versions prior to 2.1.2, we do recommend everyone update to the latest version. Updating from version 2.1.0 does not require resyncing indices however updating from much older versions does require resyncing indices.
Hi @zelus_pudding , hope you are doing well. I am currently facing an issue regarding omnisearch. I have been using it for a couple of months and it was doing really well. I have indexed a couple of datatypes previously and I used your sync template to sync them in algolia and it was fine. Recently I had to add another datatype and tried to sync the new datatype the same way but the records are not getting synced to algolia. It is creating the new index in Algolia but there are 0 records in it. I tried with different new data types and every time it will create the index in algolia but with 0 record. Also, I donāt receive the omni searcg sync email anymore when a sync is done.
I would really appreciate if you could help me figure out what the issue is, or if I am missing anything. Thanks
Believe we just followed up to your email
Just making a note here as well that weāve seen your message and are troubleshooting now.
I found a reproducible bug with the Facets system when filtering Brands that contain spaces. The behavior matches what Iām seeing in my own app. In the Omnisearch template, if you go to Brand ā Case Logic, no results filter. Brands without spaces (Sony, Monstr, Samsung, Lg) filter correctly, but anything with a space fails.
After testing multiple variations, it looks like Bubbleās DLS filter string breaks when the facet value contains a space. Iāve tried a few work arounds but I cant seem to get anything to work. Any suggestions?
Hey guys, Iām using the plugin and everything works perfect except for one thing which I think (based on just payloads comparison to the actual Typesense playground requests) if I could get resolved I could have the embeddings-based nearest-neighbor (KNN) search working.
Currently, for the search dictionary its always that portion of (missing_values:last) included which is not supported for the KNN search ā_ text_matchā field. Any chance I could have sort_by property overridden completely or maybe remove that (missing_values:last) portion somehow (see screenshot)?
Iām pretty sure thatās the smal final bit having resolved which this will just make it possible to use Typesense vectorisation and KNN search (again, as Iāve tested the payloads).
Excuse me if this has already been covered. I am trying to map two fields in Bubble (latitude = number) and (longitude = number) to a new Typesense field (location = geopoint) when sync data using Omnisearch.
Questions:
Please disregard this question. I just realized that Typesense automatically converts geographical addresses imported from Bubble into a ālat,longā format. There is no need to compose a new string by concatenating a separate lat and long.
I am using Omnisearch to integrate Typesense. Since I have no use for Algolia, is there a way to remove the Algolia part of the script to speed up my page performance? It appears to cost me 900ms on page load (see pic)
Issue with Omnisearch: socket hang up on auth.omnistore.win
Hi @zelus_pudding ,
Iām regularly encountering a workflow error when running the Update search record action.
Here is the error log:
Is anyone else experiencing this issue or is there a known fix / retry mechanism for this?
Thanks for your help!
Hi @zelus_pudding,
Hope you are doing well. I was trying to log in to check our API keys, but unfortunately Iām not receiving the sign-in link after entering my email address. Iāve tried multiple times, but Iām not receiving the email at all. My email id is productteam@focus-ps.com.au
Could you please look into this for me?
Hi @zelus_pudding,
Iām considering Omnisearch (with Typesense) for my Bubble marketplace app and want to check a few things before I commit to setting it up.
Hereās my current setup:
I have a Product data type with around 15 filter fields. Most are simple numeric or yes/no fields, for example:
I also have a Category field. Right now my search uses āCategory contains [selected category]ā as a filter. Iām not sure if my Category field holds one single value per product, or a list of multiple tags ā Iām checking this on my end, but wanted to flag it in case it changes your answer.
I currently have 9 different sort options (e.g. sort by Recycled Content high-to-low, Warranty high-to-low, Newest, etc.), each set up as a separate condition in my repeating group.
One important rule: products with verification status āActive & awaiting reviewā should be hidden ONLY when sorting by āNewest,ā but should still appear in every other sort option and in regular search results.
My main goal for switching to Omnisearch is fixing search relevance: right now, when someone searches a keyword like ādeck,ā products with that word in the Product Name donāt rank above products where the word only appears in an unrelated field. I want Product Name matches to rank first, then Category, then Description.
My questions:
Thanks in advance for your help ā happy to share more detail about my setup if useful.
Charlie
Weāre still unable to access our Scious account, as the sign-in link isnāt being received after entering our email address.
Weāve followed up via email a couple of times, but havenāt received an update yet.
We need access to the account to check and manage our API keys. Iād really appreciate if you could respond please.
