Sorry if this a newbie mistake or problem but I have done tons of other workflow “only when” statements and never had problems. Basically, ‘sms_code’ is a 4 digit code that must match what they typed in a input box ‘Input Code’. I don’t know what my problem is but any help would be great! Thank you!
This could be happening depending on what the data types are set to.
One guess is sms_code’s Type is Text and the Input is a numerical value?
If so, the Issues in the editor should be notifying you of this error and might suggest how to fix it as well (red text at the top center of the editor)
