Page Printer Problem
Using the “PDF & Screenshot Pro” plugin works fine on most screen resolutions.
However, a client using a laptop with a 17" monitor sees a PDF file printed page that is cut off to the right (see attachments - good at the top and truncated below).
Any assistance will be appreciated.
Thanks.
Make the page responsive and put a reasonable max on the :printer: printing group
Hi @code-escapee.,
Thanks for your advice.
The page is responsive and I changed the max to 2400 but the problem persists.
On my Galaxy Fold 4 the print seems Ok but it’s unreliable on a computer screen the canvas renderer is only rendering a portion of the main element…
Your assistance is appreciated.
I switched to the PDF Creator plugin and the problem is solved.
