[Plugin] BlockDocs — Notion-style block editor for Bubble (rich text, JSON output, 10+ blocks)
Hey Bubble community! :waving_hand:
I just published my first plugin and wanted to share it here — would love your feedback!
:memo: BlockDocs — Rich Text Editor
Notion-style block editing, natively in Bubble.
If you’ve ever tried to build a blog editor, a knowledge base, or any content-heavy feature in Bubble, you know the pain: native input fields are too limited, and integrating external editors is always a headache.
BlockDocs solves this. It brings a clean, modular block editor directly into your Bubble app, with zero code required.
:sparkles: What it does
  • 10+ content blocks — Headings, paragraphs, lists, checklists, tables, quotes, code blocks, delimiters, images, and more
  • Rich text formatting — Bold, italic, underline, inline code, and text highlight
  • Clean JSON output — Content is stored as structured JSON in your Bubble database (not raw HTML)
  • Read-only mode — Toggle between edit and view mode via a simple Yes/No property
  • Auto-save pattern — Use the content_changed event to save on every keystroke, no Save button needed
  • Programmatic Clear — Reset the editor via a workflow action
  • Theme-aware — Inherits your Bubble element styles (background, font, border, shadow) — no custom CSS needed
  • Fit to content — Works perfectly with Bubble’s native “fit height to content” layout option
:wrench: How it works in practice
Auto-save (3 steps):
  1. Drop a BlockDocs element on your page
  2. Create a workflow → Trigger: BlockDocs content_changed
  3. Action: Make changes to a Thing → set your field to BlockDocs's Editor Data
Load saved content:
  • Set the Initial Data property to your database field — the editor decrypts and renders it automatically
Read-only display:
  • Add a second BlockDocs element, pass the saved data as Initial Data, set Read Only = Yes
:puzzle_piece: Bubble states exposed
| State | Type | Description |
| editor_data | text | Full content as encrypted JSON |
| block_count | number | Number of blocks (use for empty checks) |
| is_ready | yes/no | True once the editor finishes loading |
:light_bulb: What I built it for
I needed a structured content editor for an internal knowledge base app. Bubble’s rich text input wasn’t enough, and iframe-based solutions were brittle. I wanted something that:
  • Stored content as structured data (not HTML soup)
  • Could toggle between edit/read-only without rebuilding the UI
  • Respected Bubble’s native styling system
BlockDocs is what I ended up building — and I figured others might find it useful too.
:link: Links
Happy to answer any questions about the implementation or how I structured the plugin. This is my first Bubble plugin, so any feedback on the listing, docs, or UX is genuinely appreciated! :folded_hands:
