Post body is empty
I’m using the API Connector and it’s not sending my JSON body when execute the post. I’ve verified this in both the Bubble logs and Stripe’s logs.
Any idea on what I should do?
25%20AM
@emmanuel any idea?
I’m having the same problem. I can verify that a simple POST request from Bubble is not getting sent to my server. @tyler.edwin.smith were you able to find a solution?
I must have got it to work, but I can’t remember how.
@dan9 @tyler.edwin.smith I ran into the same problem, I found that if you add body parameters instead of the JSON body it works.
